Advice Required On Boiler Servicing
Discussion in 'Plumbers' Talk' started by Yorkie218, Oct 11, 2018.
  1. Yorkie218
    Yorkie218 New Member
    Hi all,
    We had a new Ideal boiler fitted last November which included a 7 year warranty providing we have it serviced every 12 months.
    What would be an average price for servicing, and do we have to stick to the people who installed it ?
    Does the 7 year warranty just cover for parts only or are we covered for any of the costs of the call outs and labour charges etc ?
    Also, do the manufacturers have their own engineers to repair their boilers or is down to the people who did the installation ? .... we're not sure how it all works.
    If anyone can advise it would be much appreciated.
    Thanks in advance.
    John
  2. Allsorts
    Allsorts Well-Known Member
    I would recommend using an approved Ideal agent for the servicing. Likely cost for a new boiler, I guess up to £100.
    No idea what warranty you have - but that shouldn't be hard to work out. You will usually only get the max warranty if you used an approved Ideal installer, and then registered the unit.
  3. Heat
    Heat Well-Known Member
    You can get anyone to service your boiler if they are gas registered.
    If yearly service paperwork done then your 7 year warranty is with the manufacturer.
    I would think the warranty covers all costs, but check details provided to you, or ring the manufacturer.
    Prices for boiler servicing will vary. My area some are as little as £50 or £60
  4. The Teach
    The Teach Well-Known Member
    Its up to the visiting service technician,you may need to pay up front for repairs and claim it back from the manufacture.good luck there.
    best get the manufacture maintain your box of bits :p. some boilers need periodic service parts ie gaskets etc which are outside any warranty :(
    after the 7 year warranty your open to sales communications to purchase a new appliance.:(
  5. Dave does Gas
    Dave does Gas Well-Known Member
    £65.00 for a full service as per manufacturers instruction, Some of the larger companies will charge you more and only do a Flue Gas Reading and call it a service. IT IS NOT EVEN A SAFETY CHECK. Sorry but it boils
    my pee when Ive seen a neglected seven year old boiler being condemed after some companies claim to have serviced annually.
    Heat likes this.
  6. Yorkie218
    Thanks for the replies, it's much appreciated.
