Hi! - I am an enthusiastic DIYer currently planning an extension to my bungalow. We will have a master bedroom added to the side of our property with 3 external walls. We have triple glazing (u-value 0.8) and high levels of wall and loft insulation. We are trying to decide on the position of the radiators and wanted to ask if we would be crazy to position one in the short corridor leading to the bedroom rather than the room itself in order to save wall space - see attached photo. We would also have one in the en-suite. Unfortunately we cannot have under floor heating due to cost but would appreciate any advice. Thanks, Helen
You could consider something like this http://www.myson.co.uk/products/hi_line_rc.asp They are mounted close to ceiling level, so would not significantly obstruct walls, down side is they are fan run
I think Craig may have been smoking something . . . Certainly not a crazy idea as it's all one room, would suit me as I don't like an overheated bedroom. No possibility of a radiator under the window? Are you going to have a towel rad in the en-suite?
