AEG Intergrated fridge
Discussion in 'Kitchen Fitters' Talk' started by krissy, Oct 24, 2018.
  1. krissy
    krissy New Member
    Has anyone had trouble attaching the fascia’s to a full height AEG fridge?
    The cabinets 100% level/plumb and I’ve followed the instructions to the letter but the bottom corner (hinge side) keeps hitting the unit when opening/closing which pushes the fascia over and gives an uneven margin.
    I’m thinking that maybe the fridge is designed to take a single full height door and I’m fitting 2 x doors fixed together with plates.
    Any advice would be greatly appreciated! I’ve spent nearly a day on it so far .
    Cheers
    Kris
  2. kitfit1
    kitfit1 Well-Known Member
    Are the facia's attached to the fridge itself or to the tall housing ? Pics would make this issue much easier to sort out by the way.
  3. masterdiy
    masterdiy Active Member
    Krissy, " I’m fitting 2 x doors fixed together with plates "
    That could be your problem.
    I too have 2 doors, but you cant solid fix them.
    So post up some pictures..
  4. metrokitchens
    metrokitchens Well-Known Member
    Bring the fridge forwards in the housing a couple of mm. You will need to re adjust the door.
