Airbag restraint system.
Discussion in 'Car and Van Talk' started by Ind spark, Aug 18, 2021.
  1. Ind spark
    Ind spark Screwfix Select
    Hi all,
    Can anyone help me I have a bmw 320d 2012.
    A fault has come up saying drivers restraint system, when you plug in the computer it says seat belt tensioner short circuit to earth.
    Any ideas what I need to do?
  2. AnotherTopJob
    AnotherTopJob Screwfix Select
    Dedicated forums are your best source of information, but on most cars there is usually a plug/cable under the seat which can become damaged.
  3. jonathanc
    jonathanc Guest
    Wiring diagram and multi meter. Work through the wiring loom around the tensioner circuit to identify the issue.
  4. Ind spark
    No iv looked at that I ordered a new buckle but that didn't solve it either.
  5. Ind spark
    Wouldn't know where to start really.
