house has an optima compact panel in it, you have to walk past 2 PIRs in order to get to the panel (non-remote keypad type). Both these PIRs are on zone 2 (time inhibited). Works great when coming in through the front door, cos the entry exit is opened. However when coming from upstairs in the morning, goes straight into attack. How can I get round this? Wire all 3 (front door contact, and both PIRs onto entry exit) in series? Im a bit stumped, remote keypad woulda been the best option. Bah poor design
I could, but I'd need 3 entry exits to allow time to disable the panel. Just done it now, its only down the road, just wacked them in series in zone 1, seems to be ok. Stupid design though eh!
I could, but I'd need 3 entry exits to allow time to disable the panel. Just done it now, its only down the road, just wacked them in series in zone 1, seems to be ok. Stupid design though eh! Not a good idea, it will work but if (actually when)you get a false alarm where are you going to look? I haven't got time to study the manual at the moment but with most panels you can program enry route circuits to become final exitgs when part set. This would be a better option.
Could you expand on that. I dont get what you mean by final exits? Why cant you wire the pirs on zone two and three seperately, then programme zone two as an exit entry, so that when you walk into the room that is on zone two it will start the entry timer?
Hi all detectors on 1 zone not good, sure this is 8 zone panel, by default it puts delay on z2 if part set, are you using all the zones, if not omit an unused zone at night.won t work if the zone is programed unused but will if linked out, you then have delay on z2.
Could you expand on that. I dont get what you mean by final exits? What I mean Sparky is that a final exit circuit is one which will start the entry timer when you trigger a detector or open a door. An entry route circuit is a circuit which triggers an alarm instantly if it's the 1st zone to be triggered. If a final exit zone is triggered 1st the entry zones are ignored. What you had was a PIR on an entry route circuit and as this was the 1st circuit to trigger when coming downstairs the alrm activated immediately. Most panels have the facility to change the entry route circuit to a final exit circuit when part set. This facility is designed for the very situation you describe. If you want to go back and change it I will look at the manual and give you step by step instructions, it is quite easy once you get your head around the terminolgy.
In the old days before the introduction of remote keypads we used to put a pressure mat under the carpet on one of the steps, usually the first down from the top. this you connect n/o, one leg to one leg of the e/e zone input and the other leg to one of the tamper terminals. When you step on the pad it shorts ov from the tamper loop on to the e/e zone causing it to activate, job done.
I am pretty sure that the Optima compact can take an RKP ( check the PCB to the extreme right for the RKP connection)Any alarm supplier or electrical wholesaler can supply you with an RKP, just drop in a run of 6 core alarm cable and Bobs yer Uncle.
All you need to do is set up a programme 2 for when you go to bed. this panel has 3 programmable programmes.by default the panel will use program 1 unless told to. to set the panel by night you enter your code then press programe then press 2.
