Aligning metal back boxes for sockets
Discussion in 'Electricians' Talk' started by DavidMSmith, Feb 19, 2019.
  1. DavidMSmith
    DavidMSmith New Member
    Does anyone have any tips for precise alignment of adjacent metal back boxes in a solid plastered wall?
    I'm replacing 2 x 1 gang single boxes with a 2 gang box and a single gang box. I'd like to align the boxes so that there is no vertical gap between the installed sockets. They also need to align horizontally as well! Screwfix item code 60079 dual double/single box would be ideal except its for dry lining only. Item code 48234 is metal, but 2 x single only.
    Anyone tried using conduit fittings to align the 2 boxes with the required space in-between? Did it work? Any other suggestions for correct spacing (apart from use of spirit level and tape measure.....)?
  2. KIAB
    KIAB Well-Known Member
  3. Bazza
    Bazza Well-Known Member
    You can get box joining pieces (knockout box spacer) that give the precise spacing, BUT they only work on standard width sockets etc (like white plastic). Some metal plates are larger and these dont work.
    [​IMG]
  4. Coloumb
    Coloumb Well-Known Member
  5. dobbie
    dobbie Well-Known Member
  6. Bazza
    Did you say you wanted a double plus a single?
    [​IMG]
    click image for link
  7. KIAB
  8. Bazza
    Snap!
    KIAB likes this.
  9. KIAB
    [​IMG]
  10. dobbie
    A batten is no use on a plastered wall.
  11. Coloumb
    Bingo!
  12. KIAB
    Didn't say to USE one, but SEEN peeps attach one to a wall, me I use a laser level.:)
  13. Comlec
    Comlec Well-Known Member
  14. Bazza
    Yes. Again, with both the Spacerconnect and the TLC products, they only work with standard size sockets etc
  15. DavidMSmith
    Thanks to all for your valuable inputs. Sod's Law they will be metal faced socket & fused spur so I'll need to check if the spacing is compatible with the TLC Double + single box.
  16. spinlondon
    spinlondon Well-Known Member
    I often use two 20mm couplers to space back boxes.
    It does leave a small gap between face plates though.
