All brown wires
Discussion in 'Electricians' Talk' started by Becky78, Sep 28, 2021.
  1. Becky78
    Becky78 New Member
    Hi I would like to know how to fit a sonoff 2 gang light switch my original 2 gang light switch has all brown wires attached and one wire loops to other
  2. bright_Spark
    bright_Spark Screwfix Select
    you dont need to link the live common wires in your new one, just put your common wire into the live in on your new switch, then the two seperate switch wires into the two out terminals, the neutrals in the block connector in your back box go into the neutral in on the new switch and there you have it.
  3. Becky78
    Becky78 New Member
    So I put my 2 coms in the Lin and just use the loop wire to connect to the block in back and connect that to the Nin
  4. Bazza
    Bazza Screwfix Select
    That really should be a blue wire!
  5. Becky78
    Becky78 New Member
    Thank you
