just about to order the joists, the exact span is 4.9m plus the seating at either side (where they will be secured to the rafters with coach bolts.
I plan to use 18mm chipboard to keep the weight down, overall probably want to store around 200kg of items in the area (4.9m x 3m) will focus the boxes around the edges.
From contacting suppliers 45x145 is readily available in the length I require.
Do you think this would be suitable, from looking at joist tables this size is just slightly under.
The joist will be at 450mm centres.
I could go bigger to 170 or 190 but this becomes more awakened to install.
any advice/opinions are appreciated.
