Am I a wolly
Discussion in 'Carpenters' Talk' started by Mat1988, Jan 8, 2019.
  1. Mat1988
    Mat1988 New Member
    I've been a carpenter for 12 years but finally got myself some carpenters pencils and a sharpener in a set from Travis today for £6.
    I can't get the pencils to sharpen properly.
    I have to use so much effort to get the bloody thing to even sharpen a minute bit.
    Am I being a absolute idiot or no?
    I look forward to the replies. Go easy on me
  2. chippie244
    chippie244 Well-Known Member
    If you use one of them you are a cowboy not a carpenter.
  3. Mat1988
    Mat1988 New Member
    Only bought them as they were cheap. Think the sharpener will be binned and go back to the Stanley knife
  4. KIAB
    KIAB Well-Known Member
  5. HarDeBloodyHarHar
    HarDeBloodyHarHar Active Member
    Use a sharp chisel.
  6. Astramax
    Astramax Well-Known Member
    You should have bought the 'inexpensive' one's as they are much easier to sharpen.:D
  7. Jord86
    Jord86 Well-Known Member
    Are you a wolly?
    Absolutely not, you're a wally.
    Carpenter of 12 years, .....Stanley knife.
    chippie244 likes this.
  8. Isitreally
    Isitreally Well-Known Member
    Cheap @ £6. Those Red pencils and Sharpener :p look like pound shop specials.
    Only use Blackedge and a craft knife to sharpen here. :)
  9. chippie244
    Preferably a 4H pencil and a pencil sharpener.
    Scott Green likes this.
  10. masterdiy
    masterdiy Active Member
    I use a chain saw to sharpen my pencils. Best way ever. :)
    DIY womble likes this.
  11. goldenboy
    goldenboy Well-Known Member
    Whats all this about sharpening pencils.
    I just take pocketfulls of the screwfix ones and chuck them when they are blunt
    Dam0n likes this.
  12. DIYDave.
    DIYDave. Well-Known Member
    They often have similiar sets in Aldi for around £2 - 6 pencils and a sharpener. Bright yellow so easy to find and the sharpener does work to a degree but, often need to shave a bit more pencil with Stanley as it doesn’t sharpen evenly
    Sharpener also has an abrasive strip on one side if you need a finer point
    They’re ok for rough work but the lead (yeah know it’s not actually lead anymore) is 3/4 mm thick so if not trimmed, you get a thick line which could throw off your accuracy if you cut on wrong side of mark
    Can’t beat a Screwfix pencil or a dozen even better :cool:
  13. malkie129
    malkie129 Well-Known Member
    I have one of those pencil sharpeners. I don't use it for pencils, but for sticks of French chalk...Brilliant for writing/marking on surfaces such as brickwork or steel plate.
  14. dinkydo
    dinkydo Active Member
    French Chalk! :eek::eek::eek: I’m afraid you’ll be needing to stock up on that particular item :)
  15. Dam0n
    Dam0n Active Member
    I have one behind my ear as we speak!
  16. Mat1988
    Mat1988 New Member
    The screwfix pencils are better than the IKEA pencils. Although when we shop my Mrs ends up with a few dozen in her handbag
  17. WillyEckerslike
    Do they come with an Allen key?
    RolandK likes this.
  18. Isitreally
    Not sure, but the Meatballs are lush. :):)
  19. mr moose
    mr moose Active Member
    Pencils? Sharpening? Are we still living in the 19th century? Bic 0.7 mm pop ups every time.
  20. nigel willson
    nigel willson Well-Known Member
    No one use a marking knife anymore!
