Am I past it?
Discussion in 'Just Talk' started by peter palmer, Aug 31, 2018.
  1. Bob Rathbone
    Bob Rathbone Screwfix Select
    Yes, that works great when only the belt is changed, do you take off the secondary drive belt pulley to enable you to slide the new belt on? My Honda is coming up to 140K miles and is due bearing and pulley change.
  2. peter palmer
    peter palmer Super Member
    Trouble with mine is the water pump is driven by the cam belt and should be changed at the same time.
  3. Old Greybeard
    Old Greybeard New Member
    I've never had to remove any pulleys to do this, but have had to be fairly dextrous to get the new belt around the pulleys in the right order before trying to slide it on.
    I've not changed any other parts whilst doing it, either, in each case it was a change of belt before an MOT where I knew it was going to get revved like hell for the smoke test.
