American fridge freezer cable to short
Discussion in 'Electricians' Talk' started by Peter lee, Sep 25, 2021.
  1. Peter lee
    Peter lee New Member
    Hi guys,we have just bought an LG american fridge freezer,but the power cable is to short to reach the plug socket by about a foot.
    Can anyone advise if its OK to change the cable for a longer one,and what size in technical terms do I need to order.
    Many many thanks in advance for guidance with this.
  2. CGN
    CGN Screwfix Select
    You’ll invalidate the guarantee. Just use a short extension lead.
  3. Peter lee
    Never thought about that,Thanks for the advice
    CGN likes this.
  4. woodbutcherbower
    woodbutcherbower Well-Known Member
    CGN's advice is 100% bang on and totally the right call.
    Just a heads-up for anyone else reading this thread - if you cut the factory-fitted moulded plug off any appliance - you'll immediately void your warranty. Short extension leads are always the way to go.
    Just remember to switch the wall supply 'on' before you hook up your extension lead, plug your appliance into it, and install it.
    *SPENDS AN HOUR REMOVING AND REINSTALLING PERFECTLY-FITTING INTEGRATED FRIDGE-FREEZER BECAUSE HE FORGOT TO DO IT*
    ElecCEng, CGN and pppmacca43 like this.
  5. Bazza
    Bazza Screwfix Select
    Better to use one of these. To extend the flexible cable.
  6. Bazza
    Really?
  7. pppmacca43
    pppmacca43 Super Member
    Yeah that is true
  8. CGN
    CGN Screwfix Select
    That’s a mistake any idiot can make mate :D
  9. Tony Goddard
    Tony Goddard Screwfix Select
    No, not true, my business is an agent for 5 manufacturers of appliances and handling warranty claims for the makers is something we do, none would consider the warranty void if a plug was cut off, however the warranty would be voided if incorrect wiring of the new plug resulted in damage or if a call out was made under warranty and the fault was the plug wiring, in which case the call would be charged for.
    The advice from the manufacturers tends to read that if the replacement of the moulded plug is required it should be done by a competent electrician or "if in doubt contact a qualified electrician"
    Of course if you try and replace the lead then you will often invalidate the warranty by dis-assembling the appliance, not to mention the issues you will likely encounter with crimp connectors etc, or using the wrong cable type, a common one we get on a particular cheerful vacuum cleaner is people using a pattern part mains lead from the web, sold as compatible, its a perfectly good 0.75mm HO5 vv-F two core lead, but the genuine part is HO5 V2 V2 F, consequenty with the pattern part and some heavy cleaning you end up with a big blob of melted pvc in the cord winding cassette!
    FlyByNight and nigel willson like this.
  10. woodbutcherbower
    With the utmost respect, I disagree. End-users don't disassemble appliances, use electrical crimpers, soldering irons or incorrect cables, they don't buy Chinese knockoff cables from Ebay ......... but they do cut off plugs.
    Almost every appliance I install as a professional joiner (500+ kitchens and counting) - the installation manuals clearly state that 'The supplied plug must not be cut off or removed under any circumstances. Doing this will invalidate the manufacturer's warranty'. This applies to Howdens, Wickes, Homebase, Magnet, Wren, DIY Kitchens, Benchmarx and B&Q.
    The only manufacturers warranty it doesn't invalidate is the one offered by IKEA - who state that 'Cutting off the plug is not allowed. But if you do this, we will forgive you if:
    1 You drive a Volvo
    2 You spend a lot of time listening to ABBA
    3 You have a pet moose
    4 You hate people from Finland, Denmark and Norway
    5 You eat a lot of fish guts, hotdogs and Daim bars
    6 You like one-way walking 0.5km past stuff you hate, to get to the 'Aarsenholen' £0.99 picture frame you actually want to buy
    7 You like being in a part of the world where it is daylight for 22 hours in the summer, and dark for 22 hours in the winter
    8 Your hero is that chef guy from The Muppets
    pppmacca43 and CGN like this.
  11. Tony Goddard
    Well, all i can say is it's not a situation I've encountered, and we've sold many thousands of appliances and serviced, often under warranty many more than that, and i've had this self same discussion with manufacturers on the phone and always been assured its not a problem. Thats not to say every manufacturer takes the same line. but its not universal.
    And there is a considrable problem with pattern parts that don't live up to promise, we see at least one case a week!
    Bazza likes this.
  12. woodbutcherbower
    I'm sure you're quite right Tony - you're obviously very experienced in this business. But on balance, I think that the best shout is not to cut off a factory plug. Then there's zero comeback irrespective of individual manufacturer policy.
    pppmacca43 likes this.
  13. robertpstubbs
    robertpstubbs Screwfix Select
    You disconnect (unscrew) the existing cable/plug at the appliance end, and then attach a new longer cable/plug. If you need to make a warranty claim you swap the old one back in.
    candoabitofmoststuff likes this.
  14. AnotherTopJob
    AnotherTopJob Screwfix Select
    I think manufacturers often state exclusions like this to deter any modifications by inexperienced DIYers.
    If an appliance needs repair I don't think any reputable manufacturer could refuse due to the unrelated issue of a different (but correctly wired and fused) plug being fitted.
  15. Bazza
    Most come with a moulded plug.
  16. AnotherTopJob
    I think he was referring to replacing the whole cable right back to the terminals in the appliance.
    If it's not a simple block connector though, I'm sure it will be obvious it's been tampered with.
  17. Bazza
    Ah, yes:oops:
  18. CraigMcK
    CraigMcK Screwfix Select
    They cannot void the warranty if the failure can, in no way, be connected to the plug being cut.
    In the same way a car manufacturer can’t void the warranty on the whole car if you were, for example, to change the brake pads.
  19. nigel willson
    nigel willson Screwfix Select
    Nah, most instructions I’ve seen say “ if you have to change the plug because of”. Don’t say anything about voiding warranty. I’ve done loads over th3 years
    Bazza likes this.
  20. Bob Rathbone
    Bob Rathbone Screwfix Select
    If you are concerned about warranty, do not cut off the plug to extend. Use a short extension lead, provided that this is not excluded in the user instructions. It takes a level of skill to fit a plug, but anyone can use an extension led without formal training or certification.
