D.Blanchard
New Member
For the 10 days the kitchen sink has been leaking from the AAV on the P Trap. I've taken all the pipework off, cleaned it and made sure nothing was blocking the pipe. I've also run a drain snake down as far as I could, and flushed it out with drain unblocker. The sink has a dishwasher outlet on it. When the dishwasher drains that is when the leaking is the worst. Other than buy a 'normal' p-trap (one that isn't anti-syphon) I can't work out how to stop it leaking. All the joins on the pipework are fine as well, the only leak is from the AAV.
