Any ideas? I’ve never come across this before.
Discussion in 'Builders' Talk' started by Cheryl Pithie, May 16, 2019.
  1. I’ve taken on another refurb job and under all the wallpaper is this.
  2. mcooper2406
    mcooper2406 Active Member
    What's the issue? Identifying it or what to do with it?
  3. Sorry I kind of assumed by the title, what is it? It's clearly plaster of some kind as it is smooth as a baby's bum, but I've never seen it in sheets before, like preskimmed board?
  4. Astramax
    Astramax Well-Known Member
    Looks like cracked plasterboard joints where it wasn't taped prior to plastering.
  5. Reckon you’re spot on! Cheers
  6. fostyrob
    fostyrob Active Member
    With all due respect, how much refurb work have you done previously prior to encountering plasterboard?
    I suspect it has never been skimmed but simply papered over, hence the lack of taping of the joints.
    What to do with it depends on your plans. You could either re-paper over it after making good filling the holes and joints or skrim tape the joints and give it a skim of plaster.
    Astramax likes this.
  7. Astramax
    Fill the cracks and use WallRock Fibre Liner to cover over it all. ;)
    Cheryl Pithie likes this.
  8. Sounds like a plan. Thanks
  9. Er, well that’s clearly not with respect is it?
  10. BillyT
    BillyT New Member
    Why on earth would anyone want wallpaper that close to the bath.
  11. Astramax
    That's how things were done until 4" Pilkingtons became widely available to the masses! ;)
    dobbie likes this.
  12. David Hatim
    David Hatim New Member
    Asbestos?
  13. dobbie
    dobbie Well-Known Member
    The best idea for that is to take the bath out then overboard and skim or preferrably rip it off,plasterboaed and skim.
  14. dobbie
    A lot of people used to use a wallpaper in the bathroom called Contour, which as far as I know was made for this.
  15. Astramax
    Also Known as Tile on a Roll.
    dobbie likes this.
  16. goldenboy
    goldenboy Well-Known Member
    There was one kind that you could use on walls and floors!
  17. chippie244
    chippie244 Well-Known Member
    What bath?
  18. chippie244
    Have a load of posts been deleted from this as it makes no sense?
  19. Astramax
    The bath seen by ENLARGING the photo.
  20. chippie244
    And looking at the tiny bit in one corner.
