Any problem with this install?
Discussion in 'Electricians' Talk' started by Pollowick, Apr 16, 2018.
  1. Pollowick
    Pollowick Well-Known Member
  2. facilities
    facilities Well-Known Member
    Unbelievable:eek: why would you have so many half used toilet rolls on display!
  3. Peterdevon
    Peterdevon Member
    I don't like the clamp on the lead cable
  4. facilities
    Come to think of it that string holding the cable up could do with being a tad thicker,
    Jimmycloutnail likes this.
  5. goldenboy
    goldenboy Well-Known Member
    Biggest issue?
    The use of Ecover.
    That stuff works about as well as Duncan Goodhews shampoo.
  6. robertpstubbs
    robertpstubbs Member
    You might find this shocking:
  7. Isitreally
    Isitreally Well-Known Member
    Missed a trick, a little tighter and could have hung their washing on it.
  8. robertpstubbs
    I prefer using coat hooks to support my cabling.
  9. goldenboy
    Truly shocking.
    There should be some kind of telethon to raise money to educate those conned into buying Ecover.
    Especially in industrial quantities like that.
  10. Pollowick
    Friends of mine have to use Ecover - or similar. They have a three stage septic tank system and use of normal detergents and cleaners kills off the bacteria resulting in horrible smells where the system finally empties out.
