Any short and fat
Discussion in 'Plumbers' Talk' started by Deleted member 33931, Feb 12, 2018.
  1. unvented indirect cylinders?
    Probably need to be around 150 litre.
    Thanks.
  2. Dr Bodgit
    Dr Bodgit Well-Known Member
    I think you'd struggle, as they would need to be unnecessarily strong.
  3. Thanks Bodge.
    Hadn't thought of that. Why would squatness matter, tho'?
  4. KIAB
    KIAB Well-Known Member
    Tempest Cylinder TSMD150 ?
    Deleted member 33931 likes this.
  5. Dr Bodgit
    Short and fat has more surface area on the curved surface, so needs to be stronger there, easier engineering wise to have the other side longer. Strongest possible shape is a globe.
  6. Telford do a horizontal cylinder which is a possibility provided it ain't too long.
    Many thanks gents :)
  7. KIAB
    Vaillant uniSTOR 150l also a 120 ltr version available.
  8. Pollowick
    Pollowick Well-Known Member
    Give RM cylinders a call 01924 22 42 82 and see what they can supply or manufacture - for some they will make to your size.
  9. The Teach
    The Teach Active Member
    They can be made to order ;)
    But you can email the cylinder manufacturers on what size you need,they sell cylinders all around Europe for domestic and marine use.not all cylinders are advertised in the Uk.
    Not a fan of horizontal unvented o_O
  10. Thanks folks.
    It would really have to be off-the-shelf for cost considerations.
    Why don't you like horizontal ones, t'Teach? Any drawbacks to them?
  11. Pollowick
    RM Cylinders do not appear to have a very large premium for specials - if any. The last quote from them which included moving the Coil fittings, moving a flange and adding an extra flange was about £20 extra. Give their Tech Support a call - he is always helpful.
  12. Blimey, I'm surprised at that! Worth considering then.
    Cheers Pollo.
