Any windows fitters for advice please?
Discussion in 'Builders' Talk' started by unlockedinferno, May 16, 2018.
  1. unlockedinferno
    unlockedinferno New Member
    I recently had some windows fitted and they all have a gap between the window and the sill, I’ve recently been told by the fitter this is for drainage but that does not make any sense to me. To me is looks like they have been poorly measured.
    Any help would be much appreciated
  2. Astramax
    Astramax Well-Known Member
    Yes it's for drainage, I would be more worried that the sill in the photo doesn't have any overhang.
    dobbie likes this.
  3. dobbie
    dobbie Well-Known Member
    Looks a right lash up,have they left the old frame in,measured that too small and tried to fill the gap.
  4. HarDeBloodyHarHar
    HarDeBloodyHarHar Active Member
    Agree on both.
    And the lip you see here should sit over the end of the masonry(it's called a 'drip' for a reason).
    Looks like your has been plastered after the sill was fitted though.
  5. allrounder55
    allrounder55 New Member
    Basically if the sill doesn't protrude enough water can run back onto the external wall causing damp. If the pointing has failed it can bridge through if there's debris in the cavity.
  6. unlockedinferno
    Thanks for all who have replied.
    Is their a soloution for drainage that would make the windows look better as at the moment i think they look awful?
  7. Amusementman
    Amusementman New Member
    Thin plastic strip but make sure you leave a little little gap for water etc.
    And yeah not best job in the world but seen worse
