Wont let me edit it ! Here goes again: I have a shelf like this for my turntable very similar bur mine is made from 30mm steel box section with a wooden shelf where the turntable sits
I want to add a turntable dust cover on my turntable to protect it from dust Every time i lift the cover up i nearly catch the turntable, So i was thinking of making some sort of spring loaded runner at the back which is attached to the turntable shelf and also the acrylic dust cover. So its just a matter of lifting the dust cover and it rises and then gracefully goes back down again when not in use. I made the shelf bracket so can weld whatever onto it, I did see these But i doubt they will clear the turntable and they rise and come forward a little They are used on lift up coffee tables Ideally it would be some sort of gas strut , spring thing that was hidden on the back. I did look at building a scissor lift of some sort
Copy the old faithful! https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/263289431045
Hi thanks, thats the problem my turntable is a Michell gyrodec So if you used a normal hinge you would have to pull out the self by 200mm due to the actual size of the dust cover its 200mm high So up is the only way to go?
Please please tell me, that for all the effort your going to, it's a Michell Gyrodec. I'd love one of those. First saw one in the 70's in the film Clockwork Orange, they still look ahead of their time today.
What about having a custom made cover, in my picture, it appears to show a clear Perspex plinth, with a vertical Perspex section at the rear, hinged at the top. So, imagine your cover with the rear panel removed, fixed to the plinth and hinged at the top, the cover would simply pivot up and rest against the wall behind.
Or the flat top hinged at the back(top), and the front to drop down hinged at the bottom. Mr. HandyAndy - Really
Yes British made turntable, the one in Clockwork orange was a Michell Transcripter similar but they are discontinued now. I have had a few covers made over the years, the only problem i had with hinged ones are, they were nearly vertical when lifted up had one coming down and smashing. I know the shelf could be just pulled out a bit so when open there is more of an angle. Then i thought it would be interesting to see if there was a way to make some sort of mech thats weighted in some way to have it rise and fall...maybe i need a life?
Before I rack my brains any further to come up with a brilliant solution for you, what sort of music are we going to be pumping out of this bad boy. I don't want to be putting in too much effort for Kylie Minogues greatest hits, lovely girl, and believe me I would, but musically, no.
I play all sorts of music, don't worry no Kylie! From the Michell gyro it goes into a Bryston pre amp and into two Bryston mono block power amps (They give you a 20 year no quibble guarantee) and then into a pair of Kef reference speakers
i don't mind doctoring something? I suppose ideally something bolted to back of dust cover, some sort of track for it to run up and down at rear and some weighted way to lift it or some sort of motor mech ? I saw the heavy duty drawer runners the 3 part ones ? i may be just dreaming !
but where do you buy worm screw from ? Surely there is something that uses that sort of mech, press a button and it moves 8 inch and press it again and it moves back 8 inch ?
