Apollo 30B Pump fails to start
Discussion in 'Plumbers' Talk' started by Boots1066, Jul 31, 2021.
  1. Boots1066
    Boots1066 New Member
    Hi Mike, pump supply I believe comes from the boiler via the pump overrun stat. to eliminate malfunction of this stat I am going to purchase and replace the stat
  2. Boots1066
    Thanks Teki
    Teki and pppmacca43 like this.
  3. Mike83
    Mike83 Screwfix Select
    If the boiler is wired correctly then a faulty pump over-run won’t cause your issue as the pump would still have a power source.
    But if the boiler was incorrectly wired originally (boiler could work without issues) then a faulty pump over-run could cause the pump to have no power.
    The pump will always receive a power source from either the permanent live or switched live. But if there’s no permanent live then that could be the problem that’s now been highlighted by a faulty pump over-run stat.
    pppmacca43 likes this.
