Arc on end of breakfast bar
Discussion in 'Kitchen Fitters' Talk' started by sean r, Sep 3, 2010.
  1. sean r
    sean r New Member
    Hi can any one tell me the best way to cut 2 arcs either side of one end of a breakfast bar measuring 100mm on each doing it with a router many thanks
  2. Captain Leaky
    Captain Leaky New Member
    I make a former and use that to guide the router.
  3. blueassedfly!
    blueassedfly! New Member
    100mms a tight radius hope you have edging clamps! personally i have a jig that does radii!
  4. Captain Leaky
    I should have said "jig" not former! Oops!
  5. sean r
    sean r New Member
    thanks for all your replies where can i get a radii jig thanks
  6. Captain Leaky
  7. Joelp1
    Joelp1 New Member
    the edging can be very awquard on such a shallow angle, where it meets the bullnose.
  8. russ295
    russ295 New Member
  9. Captain Leaky
    Very good point!
  10. silly cone
    silly cone New Member
    How do you guys get around fitting laminate worktops to curved base units?
    I have done the curved radius on a breakfast bar as above using the arc on my trend jig and filed edging which is very tricky. But the curve on the base units appears even tighter.
  11. blueassedfly!
    i dont fit postformed woktops over curved base end units, if i supply them then i go for a straight edge laminate or timber or granite!
  12. russ295
    russ295 New Member
