Are different makes of flue compatible?
Discussion in 'Plumbers' Talk' started by hopefulBuilder, Sep 14, 2018.
  1. Is there a "standard" for the usual 100/60 boiler flue?
    eg. will parts from a Worcester 100/60 flue fit an Alpha 100/60 flue or an Ideal boiler 100/60 flue exit?
  2. kiaora
    kiaora Well-Known Member
    Hi
    The issue here is all boilers must be installed as per the manufacturers instructions.
    The instructions are to fit there flue, .......
    Others do fit, but the instructions are paramount, above the gas regs in fact..
    Regards
    Peter
  3. Mike83
    Mike83 Well-Known Member
    Some flues are the same. Baxi/Potterton. Vaillant/glow worm. But not always the case.
    An experienced engineer onsite will be able to make a decision, otherwise just use the specific flue for the boiler.
  4. Thanks for the comments.
