My brother has recently moved house and when he programs the timer to just call for hot water the upstairs radiators also come on and the downstairs remain cold as they should do. Why when calling for hot water is the heating coming on ? Also he has been told that he has to leave at least one radiator cracked/open even in the summer, the guy who he bought it off couldn't give any reason for this but just said he wouldn't like to see what happens should all the radiators be closed. Any ideas on either problem would be greatly accepted. Thanks in advance for any suggestions. Mark
Ignore my last post. The boiler is a Glowworm Hideaway and he cant find a pump or 3 port valve anywhere so he thinks it must be a gravity fed system, unless the pump and valve are boxed in somewhere he cant find. Thanks
http://www.glow-wormorders.co.uk/manuals/pdf/Boilers/Hideaway60CFUIS.pdf This is a boiler manual. the pump is often inside the boiler casing on these, the 2 or 3 way valves will probably be in the airing cupbosrd-if there are any but could be anywhere.
Sounds like its a gravity hot water system so there probably isnt a zone or a diverter valve.If theres 4 22mm water pipes coming off the boiler, its deffinately gravity hot water. This means that when its on hot water only,the up stairs rads will be getting hot by the water flowing up on its own. There may be an antigravity valve that might be blocked or passing,easy solution is to have trvs fitted then simply shut off the rads. As to not shutting off all the rads ? turn them all off if you want , wont cause a problem at all , just leave the pump off as it wont have any where to pump the water.
