Example Say gu10 down lights in lounge, you cost to lift flooring above to install correctly Cowboy; costs no intention of lifting flooring above, but notch plaster board ceiling to pass cables Who’s getting the job? RS
Don’t do a lot Main problem price Yes I lift/cut chipboard flooring Methods; http://www.screwfix.com/app/sfd/sea/searchresults.jsp;jsessionid=1ZQHWWN12CLNACSTHZOCFEY?dyncharset=UTF-8&howMany=15&searchText=77885 Jig saw All purpose saw Rip saw Hand saw Others may use various methods RS
What about a tiled bathroom above? Or laminate flooring that will never go back the same way it was before?
It would never be possible to declare ceilings as a safe zone for one simple reason - it is the one place in a room that is almost guaranteed to be riddle with nails and/or screws - when it is eventually overboarded.
I have often wondered if a void less than 100mm high would be considered a prohibited space through which to run cables.
Unless cables are in steel conduit, then you could consider anywhere else as a possible risk by damage, as a result of nail, screws etc, even in the permitted areas..
