Basic Boiler help
Discussion in 'Engineers' Talk' started by Movieman334, Jul 21, 2018.
  1. Movieman334
    Movieman334 Member
    Hi gents,
    I was wondering if someone could help me to know what the blue circled knobs do on my boiler?
    Also where is a good place to buy the black spanner to remove the magnaclean lid (the original has gone walkies :()
    Thanks all !
  2. Vin
    Vin Active Member
    The knobs are isolation valves.
    They allow you to isolate the boiler from the respective pipework.
  3. Movieman334
    Movieman334 Member
    Thanks a lot of in do you know which ones I should turn to isolate the magnetic filter and also which one should I turn to top up the boiler as the pressure is running a little bit low thanks
  4. The Teach
    The Teach Well-Known Member
    lots of valves :D
    From left -right (under boiler)
    black=central heating flow isolation valve.tech use.
    yellow=inlet gas supply.tech use.
    blue=cold water inlet combined isolation & filling loop.user use.
    blue=filling loop.user use.
    black (uncircled)=central heating return isolation valve.tech use.
    Floor level.
    black circled and uncircled same valve above=magaclean isolation valves.
    brass stopcock=mains water inlet.an optimal fitment.
    Like everything these days youtube has videos.
    top up pressure on your boiler,
    magna cleaning
    when its all put back together during re-pressurising The magna clean could leak water from the lid.When that happens we exchange the complete magaclean :(.
    The tools are available from magnaclean parent company adey or ebay :) Although the lid is just above handtight.
    good luck :)
    Vin likes this.
  5. Movieman334
    Movieman334 Member
    Brilliant thanks for such a comprehensive reply. I've ordered a replacement magnaclean spanner and I had no idea to turn both the blue taps under the boiler!
