Bath P bend
Discussion in 'Plumbers' Talk' started by Blue488, Jul 26, 2021.
Should I put in a p bend?
  1. Yes
    0 vote(s)
    0.0%
  2. No
    0 vote(s)
    0.0%
  1. Blue488
    Blue488 New Member
    Hi wanted a bit of advice.
    I thought all waste pipes needed some type of trap U bend, P bend, S bend etc.. I pulled off the bath panel and noticed that my bath has not got one? The pipe from the bath goes into a hopper outside, where as the shower, sink and toilet all have traps and go into the soil pipe. The properties on the street are old (around 120 years) and the street doesn't have separate rain water and waste water drainage. I've never had any smells or issues with the bath but should there be a trap?
  2. AnotherTopJob
    AnotherTopJob Screwfix Select
    If you were installing new pipework then yes.
    However, if all is well and there is no reason to disturb anything I would be inclined to leave it as it is.
  3. just pumps
    just pumps Screwfix Select
    The traps holds water to stop smells from a soil pipe entering the room, yours has an outside hopper (air break) so no trap required.
  4. Tricky Dicky
    Tricky Dicky Active Member
    My fathers plumbing on his 100 year old house is similar, hopper externally, no trap on the bath waste. No smells, but when the wash hand basin is emptied is sound of running water is held quite distinctly from the bath plughole.
  5. FlyByNight
    FlyByNight Screwfix Select
    If worried you could always fit a Wavin/Osma Hepv0 https://hepvo.com/ in line with a membrane and waterless.
  6. pppmacca43
    pppmacca43 Screwfix Select
    As said above will be fine without trap, if u ever do any work on it, fit a standard bath trap then if u wish
  7. Blue488
    Blue488 New Member
    Thank you I will leave it as is
