Bathroom ceiling paint advice
Discussion in 'Painters' Talk' started by Anjali, Jul 3, 2018.
  1. Anjali
    Anjali New Member
    Hi,
    Need an advice if someone can throw light as I am stuck in between while painting my bathroom ceiling.
    Issue desc
    had peeling on the ceiling(plasterboard)I scrapped off the loose paint from area affected .applied two coats of primer& undercoat on the board.
    Now I was about to apply paint ,realised the surface is still not smooth.
    Can anyone suggest what shud do to first smoothen the surface before applying paint.surface looks like this currently as in attached.
    I am quiet new to it so any help is very much appreciated.
  2. Anjali
    Anjali New Member
    Thx much for response .so I dnt need any filler to smoothen edges and would nt show after painting having used pink emulsion what u mentioned.
    Is pink emulsion as you mentioned will act both paint and filler and I can ignore my dulux paint bought or need to use both.
