Bathroom door latch
Discussion in 'Carpenters' Talk' started by Suraj Garg, Mar 7, 2022.
  1. Suraj Garg
    Suraj Garg New Member
    I am looking at replacing the latch (and only the latch as the rest of the mechanism works fine) of our bathroom door. The latch has a part on the inside which is used to lock from inside and also an external part which has a slot in case one has to open it from outside.
    I am looking for this specific part only but can't seem to find it anywhere online. I don't want to replace the entire thing. Can anyone point me to where I can find the said part or set of parts?
    Thanks!
  2. FlyByNight
    FlyByNight Screwfix Select
  3. Suraj Garg
  4. I-Man
    I-Man Screwfix Select
    put up a photo of what you've currently got
  5. Suraj Garg
    I've added the pics now. Hope this helps.
  6. I-Man
    put up pics of the latch, i.e. the side of the door
  7. Suraj Garg
  8. I-Man
    you'll have to replace the entire unit..
    What's wrong with the latch?
  9. Suraj Garg
    If you look at the first pic, the outer knob is missing. This makes the knob on the inside removable. This is a risk for someone to get locked in and no way to unlock from outside. Given that there are kids at home. So looking at replacing the knob-spindle set only and not really the entire mechanism.
    The other option would be to replace the entire mechanism then, which I want to avoid!
  10. FlyByNight
    You may be able to scavenge a suitable pair of bright chrome knobs from a turnkey set as a cheap option.
    I-Man likes this.
  11. I-Man
    Like flybynight said, maybe be able to buy a cheaper set and use the parts from there
  12. jacobite
    jacobite Member
    Carlisle brass sp104cp spindle for turn and release for bathroom 4.9mm 67mm spindle polished chrome at 6.14 on line.Hardwareand handles.
    Suraj Garg likes this.
  13. Suraj Garg
    I finally found what I was looking for. @jacobite thanks, I saw your message only. I got one from amazon 'Brass Polished Chrome Plated Bathroom Thumb Turn Replacement Spindle Door Lock'. Another name for this is bathroom snib bar.
