Bathroom motion sensor
Discussion in 'Electricians' Talk' started by PEAENJAY, May 12, 2018.
  1. PEAENJAY
    PEAENJAY Member
    I want to replace the bathroom pull light switch with a ceiling mounted PIR. The ones I have found so far (on ebay) don't seem to be suitable to run a ventilation fan. I want to run both the light and timed fan together. Is there a suitable ceiling mounted sensor available that would do the job ?
    Spike_hiker likes this.
  2. Hollie
    Hollie Member
    Yes
  3. PEAENJAY
    PEAENJAY Member
    Can someone suggest a brand and model number ?
  4. KIAB
    KIAB Well-Known Member
  5. dobbie
    dobbie Well-Known Member
  6. gpierce
    gpierce Active Member
    Its a terrible idea.
    My ex's parents did this at their house.
    How long do you set the timer for? 5 mins? You don't want the light on for half an hour everytime you go for a pee. Problem is you'll end up in the dark in the middle of a shower, or when sat down doing your business, and have to start waving your arms around to get the damn things to come on again.
    My experience of this was after the timer ran out and the lights go off, it takes about 2 - 3 seconds for the PIR to detect motion and turn the lights on again.
    Total and utter PITA - and it wasn't installed by some have a go hero, my Ex's dad was a very experienced electrical engineer, who designed and installed a lot of what sounded like fairly complex electrical systems for factories, he really knew his stuff. So unless there are PIR's that either use different tech that constantly monitors the room for movement, I'd steer clear. After a year of fiddling, adjusting, playing around etc, they went back to a switch. It was hardly an inconvenience.
  7. Bob Rathbone
    To contradict the previous post, it's a great idea, used it at my last house to stop the kids leaving the light on and to control the fan. In my present house 2 toilets/cloakrooms have PIR sensor lighting and fan control. If it is good for you or not really depends on how you use the bathroom, how long you stay in the bath, or is it mainly a shower room, anyhow, if it goes dark, just wave your arms in the air.
  8. retiredsparks
    Fitted one 1 year ago....utility room toilet.....
    20mm deep slimline...adjustable settings...grandkids love it.........
    switch was in wrong place..in a new house....
    works like a charm.....no problems...
    Cant recommend them enough.
    Ten quids..
    Rs
    masterdiy likes this.
  9. RolandK
    RolandK Active Member
    I thought a motion sensor in the bathroom wad to automatically flush the loo
    PhilSo likes this.
  10. Bazza
    Bazza Well-Known Member
    You could use one to do that.
  11. masterdiy
    masterdiy Active Member
    I put a PIR light switch only in my BR.
    Fan comes on with shower pull isolator switch.
    Yes the G kids love it too.
    In the 2nd loo I put an LED dimmable 300mm square light.
    Sit on loo & play with remote, different settings for colour & lighting.
    All the top places have these now......:D
    eBay item number:
    27320181471
  12. Bazza
    eBay item number doesn’t work. Do u have a url pls?
  13. masterdiy
    273201814711
    This one listed is 45x45cm which is the one I purchased.
  14. JP.
    JP. Screwfix Select
