Bathroom wiring zones
Discussion in 'Electricians' Talk' started by DIYDave., Jul 24, 2019.
  1. DIYDave.
    DIYDave. Screwfix Select
    hi all, just some clarification required please;
    I’m looking at putting a shaver socket inside my sink cupboard , (regular type cabinet, 2 doors)
    Socket use is as intended, shaver, toothbrush charging
    Recently got new electric shaver, family electric toothbrushes, etc, and new battery technology (I guess) they only need charging around every 3 weeks
    Can’t stand clutter and like absolute minimal look so, would now rather have charging bases inside sink cupboard (as used infrequently now) This is also part of a bathroom make over
    Power to socket would have to come from bedroom ring, carpet being replaced soon so access to floorboards and I know exact cable runs
    I’m thinking to spur off bedroom ring, come up inside sink cupboard, 3A FCU, then to shaver socket
    Sockets are RCD protected although realise that bathroom leccie works comes under Part P / special
    location ?
    Can’t seem to find any exact answer to what Zone is inside sink unit
    Can see basin is Zone 2 and extends around basin, 600mm from basin, bath edge is out of Zone
    Under bath, depending if panel is removable with a tool or not decides on what Zone comes under but nothing about inside a sink unit
    You’re thoughts would be most welcome guys (and girls ????) :)
  2. Pollowick
    Pollowick Screwfix Select
    Don't buy a pure shaver socket, you need one that is also rated for toothbrushes. MK upgraded theirs a few years back and the logo shows a razor and toothbrush. Some other brnads have also upgraded but some have not.
  3. DIYDave.
    Yep thanks for that, have read about this ‘possible’ issue but not convinced
    Have 2 shaver sockets at home, both with only shaving logo on, have used both for shavers and toothbrushes and other grooming implements with no ‘apparent’ problems
    Socket in main bathroom must be 20 years old and en suite around 9. Both still working so ?? Just lucky perhaps ?
    Any thoughts on my zone question ?
  4. Pollowick
    I have several examples of shaver sockets where the face plate has cracked due to use of electric tootbrushes being charged for 24 hours.
  5. DIYDave.
    As I said, perhaps I’ve been lucky then with both shaver sockets
    Got 4 leccie toothbrushes in house and they’re older models so only hold charge for couple days. Always have toothbrushes on permanent charge in both bathrooms, main bathroom charger gotta be 20 years old. In fairness though, not had electric toothbrushes that long but certainly last ten years would say one has been plugged in 24/7
    No cracking or discolouration to faceplate and just shaver logo
    Anyway, new toothbrushes hold charge for ages, hence I want to put shaver socket in sink cupboard and remove wall mounted one
    Not an essential job I realise, just wanna know about the FCU being in sink cupboard / zones / rules and regs etc !
  6. Comlec
    Comlec Screwfix Select
    There is no zone around a sink only a bath or shower
    Bazza likes this.
  7. Comlec
  8. peter palmer
    peter palmer Super Member
    There never has been one. Not to my knowledge anyway. They have got rid of zone 3 but it wasn't round the sink.
  9. Pollowick
    Comlec's images are taken from the IET website - so should be considered definitive.
    However there are plenty of incorrect images out there such as:
    [​IMG]
    I wonder if teh confusion arises as te IET refer to a "shower basin" which has been mis-interpreted.
    Personnally, I don't like them immediately above a sink and using te image above would place it towards the left of the shelf next to the sink.
  10. ajohn
    ajohn Screwfix Select
    It might be worth thinking about the socket distances from a sink for kitchens as that would be consistent and makes sense. It's not very onerous to meet that. Not sure that I have noticed it in the 18th though.
    John
  11. Pete Jones
    Pete Jones Active Member
    https://www.universal-lighting.co.uk/blog/bathroom-light-zones/
  12. Comlec
  13. DIYDave.
    Apologies Comlec for not saying thanks to you for your reply to my question, re placing FCU under basin in cupboard
    As above posts, seems rather unclear and misleading info (not from yourself though) and online is the same
    Many outdated zone diagrams still showing bathroom zone 3 and ‘most’ showing a 600mm arc around basin
    I’ve just got new IP rated downlights for bathroom and on box, again shows this zone 2 around basin
    But haven’t seen any diagrams showing specifically a cupboard under a basin
    So it seems that my above plan is fine for locating FCU inside this cupboard ? (RCD protected via upstairs ring, 3A fuse in FCU)
    Many thanks once again Comlec
