Battery dead?
Discussion in 'Car and Van Talk' started by WaterBoy75, Sep 22, 2018.
  1. WaterBoy75
    WaterBoy75 Member
    Hello,
    My car has power for all the accessories (radio etc) but when I turn the key it literally dies (clock resets) and therefore will not start.
    I put a multimeter on the battery and I noticed when I turn the key the voltage goes from about 12v all the way down to 3v. Does this sound like the battery is most likely the culprit of the issues?
    Thanks
  2. Rulland
    Rulland Screwfix Select
    Battery failing when load applied, new battery time I reckon.
    WaterBoy75 likes this.
  3. WaterBoy75
    WaterBoy75 Member
  4. Isitreally
    Isitreally Super Member
    Voltage test on a battery doesn't always show if the battery is good for cranking power, cars today require a lot of power just to start and batteries have a habit of just failing.
    Try jump starting it and put a volt meter on to the battery when running, it should be around 14 volts, this will tell you the alternator is good.
  5. WaterBoy75
    WaterBoy75 Member
    Okay thanks. Just to check - if I jump it and the voltage is around 14 I know the alternator is okay and it is just the battery which is at fault?
  6. Isitreally
    Almost certainly.
    Out of interest when was it last running and you haven't accidentally left any lights on, including glovebox light,
  7. WaterBoy75
    WaterBoy75 Member
    Hey - nope no lights on. Over the last three months has randomly died when starting (clock reset - as if I had competely drained the car) about 3 times. Then it would magically start with zero issues.
    Today I was driving it fine for about 15 miles. Suddenly it won't start at all.
  8. Peter208
    Peter208 Active Member
    Could be a bad earth connection.
    DIY womble and Isitreally like this.
  9. KIAB
    KIAB Super Member
    And still don't rule out the alternator,& a faulty starter can also drain a battery.
  10. Isitreally
    Before you buy a battery, pop to Halfords and ask them to test it, you don't have to buy from them (way cheaper out there), but at leastnuoull know if it is the battey, from what you have said it could be as said above a bad earth connection.
  11. WaterBoy75
    WaterBoy75 Member
    Okay thanks. I will test that with the multimeter in the morning.
  12. Isitreally
    Alternator check above.
    How can a faulty starter drain the battery, its dead until called for by the ignition via the solenoid.
  13. Isitreally
    Test what.??
  14. WaterBoy75
    WaterBoy75 Member
    Thanks. Can I just carry the battery in, since the car won't drive now?
  15. WaterBoy75
    WaterBoy75 Member
    Thought you can test continuity on the grounding points for resistance?
  16. KIAB
    KIAB Super Member
    solenoid failure on starter can drain down a battery, as can a diode failure on a alternator.
    DIY womble likes this.
  17. HarDeBloodyHarHar
    HarDeBloodyHarHar Active Member
    Yes, a short in the starter(when ignition turned). Especially if the battery recovers to run other electrics.
  18. DIY womble
    DIY womble Well-Known Member
    Is the solanoid not fused?
  19. KIAB
    KIAB Super Member
    Most likely, but current draw might not enough to blow fused.
  20. wiggy
    wiggy Screwfix Select
    Just get a new battery the risk of being stuck at the side of the road is not worth it
