Bay Window Structure
Discussion in 'Carpenters' Talk' started by Farrow1972, Oct 15, 2021.
  1. Farrow1972
    Farrow1972 New Member
    Just noticed damp window board below our bay window
    On closer inspection the timber stud in the upstand below the window is rotten
    The upstand is timber stud clad internally with plasterboard and Newton lath rendered externally
    Is it possible to remove the plasterboard cut out the rotten studding and fit new timbers without removing the window or the external render
    How would I fix the lath to the new studs
