Best adhesive
Discussion in 'Tilers' Talk' started by markh1, Sep 24, 2018.
  1. markh1
    markh1 Member
    Just looking for some advice please, I have moisture resistant plasterboard was just going to tank this with everbuild aquaseal. Its a standard ensuite shower over resin tray, but for the cheap cost figured best to put some tanking on, easier than dealing with issues later. Getting porcelain tiles and looking for any recommendations on a good adhesive/cement to fix the tiles on the wall. I would be getting a powder mix your own type but not sure if a specific cement is needed to adhere to the tanked walls?
  2. rogerk101
    rogerk101 Well-Known Member
    Weber slow set flexible.
  3. CGN
    CGN Well-Known Member
    Slow set flexible as Roger has mentioned. Whatever brand, getting the consistency right will make a big difference to its workability, as will mixing it thoroughly with a mixer rather than by hand.
  4. markh1
    markh1 Member
    Thanks, slow set flexible it is then.
  5. KIAB
    KIAB Well-Known Member
    Mixer?
    As in paddle mixer?
    Have seen tile adhesive mixed in a Forced Action Mixer.
  6. CGN
    Yes paddle mixer, either dedicated or a £2 jobby in your drill :)
  7. Pollowick
    Pollowick Well-Known Member
    Look at the Ardex range - choose a flexible and not a rapid set version. They also do white and grey version of most with grey being the cheaper.
    Then a coloured Ardex grout to finish.
  8. markh1
    markh1 Member
    Ok thanks, like the Ardex X7G then.
  9. KIAB
    Very good product.
