Best brand for LED lamps
Discussion in 'Electricians' Talk' started by KIAB, Apr 13, 2018.
  1. KIAB
    KIAB Well-Known Member
    What's best make for led lamps, had GLS LED (BC) lamps about eight years in fittings here, a couple have started playing up,flickering, also looking for LED globe (BC) lamp.
  2. Pollowick
    Pollowick Well-Known Member
    Is there a best? Given that most, including the premium brands, are made in China then there is a chance that they may all be from the same block of factories or use the same producer of base LEDs.
    I installed some LED fittings - costly, from GreenLighting, around 10 years ago. They are on for 6 to 8 hours per day or 2500 to 3000 per year and they are still going without any problems. I also have some LAP installed - needed something cheap, quickly, and again after two years, still going.
    Just get ones with a two year guarantee.
    MGW likes this.
  3. rogerk101
    rogerk101 Active Member
    After too many failures of the unknowns, I've homed in on Philips and Osram. After about 5 years since I started using them exclusively, I haven't been disappointed with either of them yet.
  4. KIAB
    Been looking at Sylvania, Osram & Philips lamps
    Got a high stairwell to light, thought about GU10 lighting to replace current BC fitting.
    Looked at 12w led BC lamp, but wondering if it will give enough light output.
  5. DIYDave.
    DIYDave. Well-Known Member
    I’ve tried several brands over last few years in my own house as made the switch to totally LED
    Cheeky I know but tended to purchase led lamps that were packaged in such a way that I could possibly ‘try’ them at home for a week or so, look at light output, colour, how well they dimmed, etc
    If I didn’t like what I saw, I could pop em back in their box and return to store, ‘sorry, just surplus to requirements, refund please’
    So I avoided any in blister packs which you have to destroy to get the item out. Difficult to return when you simply don’t like the lamp
    Not very scientific I realise but simply by reading the lamp specs, you cant tell what they’re gonna be like - you need to try them
    I’ve settled for Integral Lamps (T Stn), available in all the usual sizes, colours, dimmable, etc. Come down in price over the last couple of years
    Their GU10s, glass, cool white are stunning. Also very pleased with their dimmable candles and have several other types around the house, all Integral brand
    Give them a try maybe :) (3 year guarantee I believe)
    KIAB likes this.
  6. Pollowick
    Integral are fairly new to the lamp market but have been around in Semiconductors for a long time - primarily in memory. Overall their quality is excellent, but I have yet to try their lamps in large numbers.
  7. KIAB
    Will give one a try.
  8. dobbie
    dobbie Well-Known Member
    Why recommend everyone else to buy the carp from led hut,then ask for a recommendation on what lamps to buy?
    Dr Bodgit likes this.
  9. Dr Bodgit
    Dr Bodgit Well-Known Member
    Perhaps KIAB has now realised the carp from LED hut is, well, carp. Got LED Hut GU10 lamps here on his recommendation and actually they seem fine, except they buzz when dimmed. But I don't dim them, so all's good.
    If or when they start to go then will look into other makes. Integral equivalents from TS are £3.40 each (just spotted that 7w aren't available albeit listed) , much the same price as LEDHut I think so worth a shot.
  10. KIAB
    When I first got lamps from LED Hut,about 5-6 years ago,they were good, no buzzing,etc,good bright white light, no complaints, but the latest ones, sadly ain't a patch on the older ones for quailty.[​IMG]
    Happen to have a new LED Hut GU10 dimable lamp here & it buzzes/hums, not impressed.[​IMG]
  11. Dr Bodgit
    Fair enough!
  12. KIAB
    Going to order a few B22 & GU10 lamps from here: http://theledspecialist.co.uk/
    Can alway put them in workshop light fittings if things don't work out.:)
  13. JP.
    JP. Screwfix Select
    I bought some GU10 warm white 6 watt LumiLife led lamps maybe what 18 months ago or thereabouts. One word to describe them - faultless. (I believe Mr K recommended these, and I think I got them from Led Hut)
    4 in the upstairs shower room, and 4 in my daughters bedroom - light quality is excellent, with none of that horrible blue tinge evident.
  14. JP.
    JP. Screwfix Select
    I know its boring but Ikea led lamps are very good, however have never tried there GU1O lamps.
  15. Pollowick
    I mneed a globe of around 2000 lumens to replace a 150 Incandescant. Ikea were teh only supplier wo could do an LED at the right level - it is again doing OK.
  16. JP.
    JP. Screwfix Select
    I've seen those in Ikea Mr P - its all good m8. Have you seen there led tungsten filament emulators?
  17. KIAB
    That I did.
  18. Stan Lee Blade
    Stan Lee Blade Active Member
    Where do you buy your lamps ?
    Just that I don’t want to end up with all your cast offs :)
    KIAB likes this.
  19. peter palmer
    peter palmer Well-Known Member
    I always used the LAP dimmable downlights from Screwfix, they aren't the brightest and the warm white is a bit too orange for my liking but they dimmed absolutely perfect with a standard dimmer no matter if you had one or 20 on the circuit. But the latest ones we got flickered like a *****, so its either the dimmers we use that have changed or more likely the downlights are missing a component or two in the quest for cheapness.
  20. MGW
    MGW Well-Known Member
    I also got caught out buying Philips bulbs as I thought they would be good quality, learnt from error now buy cheapest I can find.
