Well I have decided to get a split load consumer unit for my requirements. But there are 2 options as far as I can see a dual RCD or a simple RCD + Non-RCD bus. I havent found any of the dual RCD i.e 100mA + 30mA. This is a fairly attractive proposition as I like the idea of still having some protection on the less critical parts. Are these dual RCD units connected... 100A/100mA RCD -> Bus 1 -> 80A/30mA RCD -> Bus 2 or 100A/100mA RCD -> Bus 1 80A/30mA RCD -> Bus 2 Who does these consumer units ? I havent seen any in Screwfix or TLC ?
MK Sentry is one range, buy the box & then the breakers you want - Be prepared you won't be looking at Volex or Clipsal prices!
Hmm, MK prices are a bit steep, so maybe I will stick with a standard split load. Another option,check out MEM's range of CU's last price I got for a split-loader 100A main switch and 80A/30Ma RCD with 8 type B breakers of your choice was £69+vat Wilts wholesale stock them BTW Far better than any clipsal/volex
