free_flyer
Member
What is the best DIY tool or method to create a flat face on a needle roller bearing ?
These are the needle roller bearings..
https://simplybearings.co.uk/shop/p100096/8x8mm-Flat-Ended-Loose-Needle-Rollers/product_info.html
I need to do this to 18 needle roller bearings, I tried with an angle grinder and despite the bearings being hardened, it did remove the material.
But its not possible to get any kind of accuracy with an angle grinder and a vice.
This is the other issue, how to clamp the bearings when creating the face?
