Best handsaw under..
Discussion in 'Tool Talk' started by enc, May 20, 2019.
  1. Heat
    Heat Screwfix Select
    Are you originally Scottish, or from the Yorkshire area? ;)
    Good idea to resharpen Stanley blades. Most of the uses I have for a Stanley knife do not need a lethal sharp blade anyhow.
    On the subject of being tight and reusing things, - I reuse cable ties by pushing a small flat blade screwdriver to open the catch on the cable ties. :oops:
    KIAB likes this.
  2. dinkydo
    dinkydo Screwfix Select
    I’m like you Kiab tight as they come, wouldn’t give a door a slam myself, I also use both sides of a toilet roll
    KIAB and Heat like this.
  3. KIAB
    KIAB Super Member
    Been doing genealogy,found scottish & welsh roots.:)
    Heat likes this.
  4. Heat
    I am from Scottish ancestors as far as I can tell, which might explain my tight ways. But probably more to do with how my parents disliked waste
