Best Oil Boilers?
Discussion in 'Plumbers' Talk' started by sinewave, Jan 28, 2018.
  1. sinewave
    sinewave Screwfix Select
    Will need an Oil Boiler replacing soon in a 4 bed House with 2 Baths.
    Current unit is a combi but am looking at having a Tank maybe?
    Grant Boilers seem to be rated best by WHICH magazine however their warranty is only 2 years?
    Any views from the Oil Guys?
    Cheers in advance! :D
  2. KIAB
    KIAB Super Member
  3. Thought you had and recommended heat pumps.
    Copy of a post from 2012.
    Rip it out and install a decent Air Source Heat Pump.
    No Oil to rob, no tank and cheaper running costs as well if your house is reasonable insulated etc etc.
    Tiz what I did on my own Gaff
    KIAB and Sparkielev like this.
  4. sinewave
    Cheers Kiab,
    I've had a Mistral in the past and tbh it wasn't that reliable.
    Cost is not an issue in this case, reliability, performance, quietness and a decent guarantee are prime requirements.
  5. sinewave
    Not anymore Deleted member 11267! ;)
  6. KIAB
    KIAB Super Member
    Surprised.
  7. yorkyguy
    yorkyguy Active Member
    Had 2 Worcesters on an open vent Honeywell S plan system, twin coil cylinder, 14 rads, gravity DHW 4 oven Aga OEB and 90 galls hot water per day for 30 plus years! Didn't bother with an immersion heater:rolleyes:. If it aint broke................keep it simple.
