What's the best satinwood available? I would prefer oil based.. I've used Leyland trade goes on great but yellows in weeks Also used Dulux trade which is poor coverage and not very good flow, used to be good before they changed it. Any others to try? Would use water based but find that you need multiple coats where on a job puts days onto a job and would not get the work if a staircase takes 1 day to satinwood and suddenly it takes 2 days...
Have you thought about using V33 melamine finish paint as that covers very well and has a satin finish. Do a search.
Johnstone's satin oil is good according to the old boys that still use it. I like acrylics but maybe consider waterbased alkyd. Same as oil but uses water as the delivery vs oil
yep, I'm an old boy , I'll face up to it. Johnno's OB Satin is good, also have water based . Sometimes I toss a coin. Cleaning of the brushes usually sways the decision. Will still use 0/B on the handrails. Any other old boys out there wanna give me some tips on puttying. Today's effort was poor, do about three or four glass replacements a year. Never gets any better.
Crown Fast Flow got recommended to me on here a while back. I'm very happy with it, much better finish than any water based satin I've used before. Just make sure you always give it a good stir, even if it's only been stood still a couple of days. The element that gives it it's ability to flow nicely seems to separate from the paint itself
Leyland rubbish like you say, I learnt the hard way. Armstead water based in old place, was actually good, resistant to marks and obviously doesn't yellow. Used crown fast flow in new place as advised on here. It looks ok but I don't think its as durable as the Armstead. I think the armstead is like a synthetic water based which gives it a bit more oomph! They have been using crown on the job I was last on but not the fast flow. It looks pretty good not sure if you can get "non fast flow" water based crown.
For instance if the cleaner rubs the hoover along the skirting rather than constantly butting up to it you can get a black like with this crown, never had that with Armstead
I have told her about it and the words I used were the paint here is ****. We never had this problem in the old place. Was I right in my assumption that the Armstead is more of a synthetic whereas the fast flow is more of a traditional water based? You can even smell the armstead when you pop the lid and it smells a bit "chemically". Just speaking from experience i've had both, no financial interest in Akzonobel!
Really can't say as I have never used Armstead....used gallons of FastFlow Gloss though without any problem even in my own home!
Depending on the surface profile / size / etc / get it on quick with a 4inch roller then immediately lay off with a brush The harder compound black foam rollers leave less air bubbles than the soft white foam type and don’t roll too fast / again, encourages bubbles But again, if painting fiddly stuff, plastic downpipe, eg, a roller isn’t gonna help you Using any water based paint is like learning to paint for the first time - as Astra touches on above
Thanks have used the Sikkens water based rubbol on numerous panel doors here. Bit thin so lots of coats....purdy brush. What is the best version for satin finish and ease of use at this moment in time for my son in law who has kids and is not a 'painter'. Probably going on top of old styles gloss (not seen the house yet) Also , Have seen that some satins are up 500g/l of VOC...are these similar in performance ( opacity) to the old paints which I liked(apart from smell) cheers jim
The best paint to perform like an old oil base is Crown Trade FastFlow, you will require the primer/undercoat and either the satin or gloss top coat, the system is one undercoat and two top coats on previously painted surfaces, if new timber two primer/undercoats and two top coats. Follow instruction's on container or read Data sheet (online), sand and clean surfaces prior to painting is the key, clean brushes with warm soapy water. You will not be disappointed with the finish........failing that use Johnstone's Aqua. 4" rollers I use felt, mohair or microfibre for painting timber with water base paint, laid off with a Purdy monarch.
