Best sealant for holes in wood planks
Discussion in 'Carpenters' Talk' started by LunaticMuch, Apr 6, 2021.
  1. LunaticMuch
    LunaticMuch New Member
    Hi all,
    I am about renovating my victorian floor in a small room. Most of planks require me to remove and lay them down again but unsure how to deal with holes left by actual screws. Can I use filler and then put again screw or nail? I've read so many options around between putty vs filler where both are ok and both are not ok. What you do normally?
    Would I be able to nail back into the same joist later?
    thanks
    LM
