Best tool storage/carry case for multiple drills
Discussion in 'Tool Talk' started by Drofidnas, Aug 29, 2019.
  1. Drofidnas
    Drofidnas New Member
    Evening
    Just treated myself to a new Stanley Fat Max brushless drill last month and today bought the companion drill driver.
    The drill came with a case but the driver came 'bare' without even a case.
    As per the title, are there any recommendations for multiple drill tool carry cases/totes? Happy to ditch the original Stanley case if I can fit both drills into something with room for batteries, charger, screws, bits etc.
    Cheers
    Chris
  2. Astramax
    Astramax Screwfix Select
    Have a look at tool storage cases on ebay.
  3. Drofidnas
    Thanks. I have. I was looking for a recommendation from a user, otherwise it's buying blind.
  4. Astramax
    Have had a few cases from ebay!..............all fine and fit for purpose.
    Drofidnas likes this.
  5. DIYDave.
    DIYDave. Screwfix Select
    If your not bothered about mix and matching brands, take a look at the Dewalt TStak boxes
    SF sell a few but these are more like tool chests for general tool storage
    Can buy on EBay as an example and will hold 2 drills, charger, batteries and some spare storage, just over £20 - TStak power tool storage box
    Some TStak boxes have plastic moulded sections designed so their own drill fits in perfectly, so unlikely that your drill will fit
    Other boxes just have a foam insert with cut outs for equipment. A fair few different types available for different power tools in the Dewalt range
    Probably best to buy the foam type, replace the foam and cut out to your own requirements
    If you use any Facebook selling sights, I always see loads of new or used TStack boxes for sale
    Many of the Dewalt power tools now come in the TStak boxes but not everyone goes on to use the supplied cases, hence loads up for sale. I got two brand new ones from a mate that keeps his tools loose in a filing cabinet in his garage (no ideas why but my gain) ;)
    Worth taking a look
  6. Drofidnas
    Cheers. Thanks for all that. They definitely look the way to go. Was looking at Stanley stuff specifically but couldn't really see much. The first Tstak I saw seems to do the job. Got ready access to foam at work too so could even go for some cut outs, though not too fussed. Also looked for filing cabinets but they were too expensive and local pickups only. :D
  7. DIYDave.
    Great, hope this does the job for you
    They’re really great boxes, super tough, strong catches, sturdy handle and if you have several, they clip together so ease of carrying from A-B . Also have a little clear window and a label so again, with several, can label up the contents of each box
    A bit bulky though, perhaps that’s why some peeps don’t use them ?
    Gotta say, I like keeping my power tools in cases and for me, it’s one of the deciding factors when looking for a new tool, if supplied with a case or not. I’m diy so not particularly tied into one brand or battery system
    Enjoy your tool storage :)
  8. Wayners
    Wayners Screwfix Select
    I'm all in on tote boxes..40lt is about right and they stack well. Can also get wheel dolly. Second hand are cheap off ebay or nearly new...27lt is perfect for plunge saw.
  9. sospan
    sospan Screwfix Select
    If you have a look at Anglia tools or FFX they often sell off the empty Tstak case for £10-£20
    What they do is but the multiple tool sets and then sell the pieces individually. The piece that normally gets unsold is the case, sometime there is an insert but that can be popped out to leave and empty case
  10. WillyEckerslike
    The failure with all stacking/interlocking tool boxes/cases is that the one you want is at the bottom - always. Even with Tanos/Systainer type arrangements where you can open the lid with others stacked on top, you can't in reality if there's anything meaningful above it. The drawer types offer some versatility but you are restricted by the size of the drawers. Over the years I have built up a collection of Dynacase boxes (Milwaukee, AEG, Atlas Copco) in two sizes but they really need arranging in some pre-made drawer arrangement to overcome this issue and I just haven't got around to it yet. I have made a load of dollies with locking castors and that has made storing and moving them very easy.
    Regularly used battery tools - SDS, combi drill/driver, impact drivers, oscillating multi-tools, grinder, jigsaw, worklights and so on all get lumped together in a large wheeled trunk - a quick rummage finds what I need. The thought of a stack of boxes just for those.....
  11. Wayners
    Tote boxes..I've pulled half my racking out van now and just pile these up. Can swap depending on kit needed for job. They worked out £7 each ish..oh...S = Sanders...7 x40lt and 4 x27lt plus my sheets and vacuum etc works for me for what I carry, own a few more that store tools and kit in garage.
