BG USB sockets
Discussion in 'Electricians' Talk' started by retiredsparks, May 9, 2018.
  1. retiredsparks
    Any good..or avoid like plague ?
    or any other recommendations...
    Crabtree, schneider Mk are all about 20 quid each.
    Rs
  2. DIYDave.
    DIYDave. Well-Known Member
    Funnily enough, I bought 3 a few weeks ago, just needed standard white faceplates with USB, nothing fancy
    Ordered them from Amazon Prime, the listing stated ‘guaranteed for 30 years’
    Seems a long time to guarantee a socket for ..... not the actual socket as not much to go wrong but the charging facility. Is the seller telling the truth here I wondered
    Have had a few of these sockets that refuse to charge after a few years (various makes)
    So I emailed BG for confirmation of this 30 years as no mention of any guarantee period on socket or packaging itself. Also to ask what was actually covered for this period - the socket itself and usb charging ?
    After sending 2 emails but getting no reply, I called their customer services / tech department. They did indeed confirm that the complete socket was covered for 30 years (which to me seems rather amazing)
    I mentioned that no guarantee details appear on the packaging or install instructions and perhaps that should add this detail - surely would be a great selling point
    Person I spoke to seemed less than interested in my suggestion
    I also asked if they could email me a confirmation of this 30 year guarantee so I have something on paper - still waiting
    All I can say is mine are working after 3/4 weeks (still under guarantee for another 1,556 weeks so I can relax a little) :)
    retiredsparks likes this.
  3. KIAB
    KIAB Well-Known Member
  4. Coloumb
    Coloumb Well-Known Member
  5. Isitreally
    Isitreally Well-Known Member
    Ive got a BG one in my mancave, it work a treat, not only charging phone but a bluetooth speaker together without any drop in charging rate.
    Got my from TS.
  6. Dr Bodgit
    Dr Bodgit Well-Known Member
    Using an Avantree Powerhouse here for my USB charging needs, 4 outputs each around 2 amps.
    [​IMG]
    KIAB likes this.
  7. KIAB
  8. JP.
    JP. Screwfix Select
    I'm not into stuff like that, but Docs one does look like a nice unit
  9. KIAB
    Better than what I saw other day, a unpowered usb hub plugged to usb faceplate to charge several items at same time.
  10. JP.
    JP. Screwfix Select
    Right..dunno about all that stuff Mr K, I just use the plug in chargers which come with phones and use them. Spose one day I might buy a socket with usb outputs..seems a handy facility tbqh.
  11. MGW
    MGW Well-Known Member
    I have bought a number, some 2.1A a pair, some 3.1A a pair and some 4.2A with 4 outlets so still 2.1A a pair.
    I was getting variable results, the problem is the charge point, the lead and the device can all cause the charge rate to drop, so I bought a USB volt and Ammeter, I found cheap PoundWorld leads only charge at 0.4 amp it does not matter what outlet, more expensive leads with Samsung tablet and phone will charge at around 1.2 amp when device half charged, connecting two devices to same outlet around 1.8 amp so not the outlet limiting charge rate but the device being charged.
    Wife has new Samsung phone with connector which can be plugged in either way around, now that charges at 1.6 amp.
    Ammeter [​IMG] similar to shown. From the computer every device seems to charge at 0.40 amp. For plug in devices which this will plug into found 0.40 amp seems lowest and 1.8 amp highest output recorded to date.
    I have found some odd things, a USB extension lead made phone show charging, but ammeter showed no output, a double AA battery charger showed just 0.02 amp charge rate.
    Big advantage is once phone is charged you see charge rate drop from your chair so you know without looking at phone when it is fully charged.
    However as far as USB outlets on 13A sockets go, every one fitted be it rated 2.1 amp a pair or 3.1 amp a pair gives near enough the same output into a Samsung device. And cheap PoundWorld leads OK into PC but reduces output with wall socket.
    All I have fitted are LAP, LG or BG and all give the same results. Have installed 8 between two houses and a caravan all seem the same.
    Cig lighter chargers very different story, quite a lot only give out 0.4 amp.
  12. Dr Bodgit
    I also have one like this in the shack, more portable for travelling.
    [​IMG]
  13. Wayners
    Wayners Well-Known Member
    I fitted 2 in the our kitchen 3 years ago. Had to swap the back boxes to allow the sockets to fit. Personally.. Just buy Anker 4 port charger and save yourself the hassle and potential problems if any
  14. DIYDave.
    Like most electrical things Wayners, they tend to shrink over time !
    The BG 2G USB skt will fit into a standard 25mm back box, even with 2x2.5s entering the box
    Probably a squeeze if a spur has been added, or excessive cable length in box
    Can’t speak for all makes but few I’ve fitted last couple years have defanatly slimmed down
    This isn’t the slimline range though, standard raised white faceplate. As I’m sure you know, fitting some of these slimline sockets can be a squeeze in a 25mm box, without usb
    This may be useful to you ?
    Wayners likes this.
  15. JP.
    JP. Screwfix Select
    Very useful info MGW
  16. Wayners
    Why would anyone want a USB socket when you can buy this.. Jmo... See here im saying that when I have 2 usb sockets fitted and I can't understand why I bothered
