Biasi Compact HE 28Kw boiler loosing pressure. I thought it might be a slow leak, so i added a leak sealer to the system about 4 weeks ago. I still have a slow leak. The running pressure is kept around 1 bar at full running temp of 70C. Could it be the PRV? if so how do I check for that? Can it be any thing else? Please help.
I thought it might be a slow leak, so i added a leak sealer to the system about 4 weeks ago..............................What Muppet forum were on that adviced that!!! That's one of the worst things you can do to a combi boiler!!! Any system leak is just that a system leak, that should be detected & repaired.
Dicks a little bit up him self cos of the weather,tie a clear poly bag round the PRV outlet outside,if youve got water innit,then its leaking,thus reducing pressure. got to go teas ready.
You r feeling under the weather DickPuller, I advise taking some calpol and a soother and going to bed.
I think You were being arrogant and abusive to Puller,but thats how people are nowadays. You are the one asking advice?even if its arrogant and rude /you need to grow up and not bother coming on this site for a cheap quick fix.
I was not being arrogant, I was just infoming you that you have taken bad advice. Leak sealer will knacker your combi boiler, knacker the circulator, the heat exchanger & the divertor etc, etc.......... A leak is a leak & it needs to be detected & repaired.
