BIN Primer on MDF window boards
Discussion in 'Painters' Talk' started by DIY_Has123, Mar 4, 2021.
  1. DIY_Has123
    DIY_Has123 Member
    Does anyone know if Znisser BIN primer/sealer can provide enhanced waterproofing qualities for MR MDF window boards?
    I am worried about general window condensation moisture ruining the MDF window boards.
  2. Dr Decorator
    Dr Decorator Active Member
    Can you not use moisture resistant MDF?
  3. Wayners
    Wayners Screwfix Select
    Probably better than waterbased paints but won't stop long term water damage.
    Normal window condensation won't effect unless it's pooling
  4. DIY_Has123
    DIY_Has123 Member
    Yeah it is moisture resistant MDF. Moisture Resistant "HDF" apparently.
  5. Dr Decorator
    Ok, I would just use bullseye 123, then the relevant undercoat and topcoat
