black mould in bedroom and bathroom
Discussion in 'Builders' Talk' started by bedsplumber, Dec 3, 2012.
  1. bedsplumber
    bedsplumber Member
    hi have black mould appearing in to front bedrooms and bathroom it wipes off and is not there in summer months could this be due to ventalion had new front windows checked guttering and sofit and facia has been change
    any help ideas thanks in advance
  2. If its happened since you have had the facias changed, check that they have blocked any vents.
  3. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Keep bathroom door shut and window open/fan on until steam has gone.
    New windows, open top vent.
    Mr. HandyAndy - Really
  4. Dereekoo
    Dereekoo Member
  5. Mrs Fixit
    Mrs Fixit New Member
    Black mould is a sign of condensation.  Only black mould appears with 'clean' water.  Wherever you can, add ventilation - ie air vents/bricks.  Ensure that there is adequate heating, but also try not to introduce further water to the atmosphere - ie don't hang washing on the radiators, ensure that the bathroom window is opened after showering/bathing.
    http://en.wikipedia.org/wiki/Condensation
  6. T
    T Member
    do u have window vents? older type windows probably not. leave windows open on a the security catch
    it dont make sense, save heating yet vent ya house its madness lol
  7. petertheplumber
    petertheplumber New Member
    As far as ventilation is concerned it is worth realising that when designing a heating system the size of rad in the bedrooms allows for the air in each bedroom to be changed twice per hour, so ventilation is expected, also bathroom air should change 3 times per hour, there is no excuse for excessive condensation. Once it happens it goes black with mould because it is bacterial from breath, perspiration, etc. it can be cleaned off with a mixture of bleach detergent and water, once washed off redecoration can take place.
