blanking off
Discussion in 'Plumbers' Talk' started by SHOCKING, Feb 8, 2007.
  1. SHOCKING
    SHOCKING New Member
    i need to cap off my gas supply to my fire which is
    coming out to be replaced with a electric one how much
    would i be looking at to get someone in to cut and cap the pipe 15mm size im in essex any advice welcome
    thanks shocking
  2. SHOCKING
    SHOCKING New Member
    anyone got any ideas shocking
  3. tomplum
    tomplum Active Member
    i would expect to pay not less than £50 from a reputable plumber.
  4. iceml
    iceml New Member
    if you are confident in doing it yourself just cut and cap it yourself piece of ****,i wouldn't pay corgi to do this.
  5. SHOCKING
    SHOCKING New Member
    corgi to do this.
    thanks iceml i did think of doing it myself as i have
    about 15 years plumbing exp im not a plumber ive just
    got the exp so i thought i would ask others to see what
    advice they had to give. thanks shocking
  6. dave the plumber
    dave the plumber New Member
    A corgi registered plumber can justify charging you around £60 to cap the gas to your fire depending on how far he has to travel to do it.
    I am a corgi registered no. 221091. I would charge you £50 if you were on my doorstep and £60 otherwise.
    Make sure a tightness test is done on your gas after capping.
  7. SHOCKING
    SHOCKING New Member
    thank you every one for your replys could i get away with
    just turning off the supply tap on the gas pipe to the
    heater or could it leak or is it best to cap it with a
    15mm compression cap and gas ptfe round the olive what i was going to do is remove the gas fire and the silver
    pipe to the isolating valve and leave it as that just making sure it is turned off.
    thanks shocking
  8. kimble
    kimble New Member
    with
    the
    a
    silver
    thanks shocking
    Don't do that mate, it's against the regs as a restrictor elbow is not an appropriate fitting (even though I keep seeing it) for capping off supply.
    You can do it the proper way.
    Turn off gas, attach temporary equipotential bond, remove and cap meter, cap incoming supply, then you need to cap off the fire supply pipe before the elbow with either a soldered cap end or compression cap end (no compression under boards or inaccessible)then the installation needs to be tested with a manometer for leaks, purged, all other appliances brought back on line
    Or you can do it the DIY/Water Systems way and turn off gas stick a compression on and squirt with fairy and f.uck the regs/safety
    Or better get a competent person in who has the knowledge/ proper gear to do it right
    I'm not saying you don't have the ability with pipework but your knowledge regarding safe working with gas is a little slim (re just turning off iso)
  9. Guest
    If you don't have a manometer, check that the gas meter is not passing gas over a few hours, with all appliances off
  10. kimble
    kimble New Member
    for leaks,
    appliances off
    And potentially fill your property with gas!!
    Good call
  11. Jimbo
    Jimbo Active Member
  12. SHOCKING
    SHOCKING New Member
    thank you everyone for your help ive had the gas capped
    off by an expert and it only cost five pounds.
    thanks shocking
  13. strappy
    strappy New Member
    capped
    thanks shocking
    did he miss a 0 of his invoice :)
  14. SHOCKING
    SHOCKING New Member
    the 0 was in the pipe work, invoice what invoice :)
  15. plummit
    plummit New Member
    Just wondering how many people would check out tightness prior to carrying out any work?.
    This seems to have been over looked.
  16. smithp60
    smithp60 New Member
    Good call Plummit, Saves loads of arguments.
  17. Uncle_Whuppity
    Uncle_Whuppity New Member
    Many moons ago I always did soundness test(tightness) as norm ...once a good gas fitter always stays with you .. ;)
  18. SHOCKING
    SHOCKING New Member
    no a tightness check was carried out first thats why
    i only paid a fiver you cant get much tighter then me.
    shocking
  19. Uncle_Whuppity
    SHOCKING
    Well Done , my son ... good on your...
    where abouts you live ???
    , its just so when the UK News make a big Song/dance about your house gas explosion an death of you !!!.
    but your lovely wife an kids , an maybe next doors if terrace ...
    I can be an TV Gas adviser who knew you an advised against you doing this ...an get 100k intial shows ,25k news /media updates .....(shows after see my media agent )
    an maybe get on the Then "Celebrity Shows" ...
    SHOCKING
    Share The Love......thanks ;)
  20. SHOCKING
    SHOCKING New Member
    don't worry all the right checks were carried out by
    a corgi guy just he was working in someone else`s flat
    so i gave him a back hander and he works for a large
    company a nationwide company so i know i can trust him
