BLEEDING A TOWEL RAD (CANNOT FIND THE BLEED VALVE)
Discussion in 'Engineers' Talk' started by Daver77, Apr 28, 2018.
  1. Daver77
    Daver77 New Member
    Hot at the bottom, cold at the top, has to be air, but cannot find the valve, any ideas?
  2. dobbie
    dobbie Well-Known Member
    Are the caps at the top just plastic and pushed over the top of the bleed nipple for decorative purposes.
    Daver77 and WillyEckerslike like this.
  3. WillyEckerslike
    Exactly my thoughts.
    Daver77 likes this.
  4. Daver77
    Daver77 New Member
    cannot remove them with my hands...
  5. Daver77
    Daver77 New Member
    had another go and you were right, hard plastic caps, very hard to remove, but thanks gents
  6. WillyEckerslike
    Thanks for the feedback. The number of queries that get answered only to never hear back from the OP is quite disappointing. Hope it cures the symptoms....
    Daver77, KIAB, dobbie and 1 other person like this.
  7. Pollowick
    Pollowick Well-Known Member
    You will find that you need to bleed it slowly until water seeps out. Then wait 30 minutes or so and repeat, then repeat again. I have a similar towel rail and have found that the best way - with a few taps to get stuck air moving.
  8. Daver77
    Daver77 New Member
    thank you for taking the time!
  9. Daver77
    Daver77 New Member
    only once did the trick, it's as hot at the top as at the bottom
  10. WillyEckerslike
    That's sounds remarkably like Mrs Eckerslike!
    Daver77 likes this.
  11. Daver77
    Daver77 New Member
  12. Daver77
    Daver77 New Member
    My wife has the coldest feet I've ever encountered, luckily she didn't have cold feet when she said YES
    WillyEckerslike likes this.
  13. rogerk101
    rogerk101 Active Member
    I was intrigued to see your upside down TRV. I assume it works, but haven't ever seen one before.
