Boiler moved but need certificate for building regs
Discussion in 'Plumbers' Talk' started by Markiemark, Nov 4, 2017.
  1. Markiemark
    Markiemark New Member
    hi all
    I had my boiler moved by a plumber back in September 2015 as part of an extension we were having done by builder.
    Since then I got very ill (Hodgkin's lymphoma cancer) and have only just got back to full health.
    Anyway I'm trying to get the extension signed off by buildings control but they're saying I need a certificate for the boiler being moved.
    Can I get this from any plumber or do I have to go back to the original plumber to get a certificate?
    Many thanks in advance for any advice
    Regards
    Mark
  2. sam spade
    sam spade Active Member
    The person who moved the boiler (I hope he was Gas Safe registered) should have registered the reinstallation with Gas Safe, who would then send you a certificate to say it complied with Building Regulations.
    Go back to him and ask if he has registered the move. If not, phone Gas Safe (0800 408 5500) and explain your problem.
  3. Markiemark
    Thanks. I'll try Gas Safe. Plumber is gas safe registered or so it says but he's being allusive (like a magicians disappearing act!)
    KIAB likes this.
  4. KIAB
    KIAB Well-Known Member
    Might say Gas Safe, but being registered is a totally didn't thing.
  5. Markiemark
    So you don't need to be registered to be gas safe?
  6. KIAB
    Of course you need to be registered, but I knew of two plumbers who were advertising as Gas Safe registered,even had a sticker on van I think & on paperwork,yet they weren't even registered, your plumber might be the same.
  7. just pumps
    just pumps Active Member
    If you can`t get hold of the original guy then expect the next one to remove the boiler from the wall and check things then rehang it and check the flue and pipework, treating it as a new install before signing it off.
    Markiemark likes this.
  8. Markiemark
    I kind of gathered that another plumber wouldn't want to touch it
  9. just pumps
    They will but they will be thorough as it their name going on it.
    Markiemark, KIAB and Astramax like this.
  10. Astramax
    Astramax Well-Known Member
    That's reasonable enough as it's the persons livelihood! :)
    Markiemark and just pumps like this.
  11. Mr_bizzare
    Mr_bizzare New Member
    Any Gas Safe registered fitter would be able to check your installation in 20 to 30 minuets, most flues if not all flues are visible once once the combustion chamber is open and the integrity of a flue can be checked with an FGA. After checking the flue and combustion checks of burner, working and operating pressure and general visual opservations will satisfy a fitter used to domestic boilers. Try and find a company the carries out landlords gas checks they will be used to certifying other people's work.
  12. Markiemark
    Thanks everyone. I managed to get in touch with the plumber and he is coming on Friday to check the boiler (which he is charging for) so hopefully get my homeowners certificate that will be sufficient for building control to sign off!
  13. KIAB
    Bluddy cheek!:eek:
    sam spade, CGN and Markiemark like this.
  14. PhilSo
    PhilSo Active Member
    Still doesn't answer the question...
    Is he Gas Safe registered or just pretending to be .
    PhilSo (inquisitive).:oops:
    KIAB likes this.
  15. Markiemark
    Hey PhilSo
    Yes he is registered. I checked on the gas safe register.
  16. Sparkielev
    Sparkielev Well-Known Member
    If he fitted boiler he shouldn't really be charging you for cert
    KIAB and PhilSo like this.
  17. PhilSo
    So why didn't you receive a certificate in 2015 from Gas Safe ?
    Maybe he didn't notify Gas Safe in 2015.
    I wonder why not.:cool:
    When you booked the Friday visit (chargeable :eek:) did you ask why you hadn't received a certificate when he moved the boiler in 2015.
    Do you have a receipt/invoice from 2015.
    PhilSo (Sherlock)
  18. PhilSo
    Pleased that your health has improved :)
    PhilSo...
  19. Sparkielev
    You may as well use someone else to do cert as he is taking the ****
    KIAB likes this.
  20. Markiemark
    I agree but I want to get him to come tomorrow and then question him about it! Otherwise I think he won't respond and ignore my calls! I feel like I'm held to ransom
