Boiler pressure
Discussion in 'Engineers' Talk' started by Tristan84, Apr 1, 2021.
  1. Tristan84
    Tristan84 New Member
    Hello,
    I am trying to pressurise my boiler so I can bleed my radiators. From a bit of research on line I think I need to turn two isolation valves in order to achieve this.
    I have photographed the set up along with the valves I think I need to turn in the attached photos.
    The one right next to the pressure indicator looks straightforward however the second valve, most instructions seem to indicate I should be able to turn this with a screwdriver. The only way I can see myself getting a grip to turn this would be with a pair of pliers. Can someone advise if I am looking at the wrong thing here or if this is a bad idea?
    Thanks in advance!
  2. Mike83
    Mike83 Screwfix Select
    The second one should have a black handle on it.
    It’s been removed for whatever reason.
    So just turn it with a spanner or similar.
  3. Tristan84
    Good to know, Thanks Mike!
