Boiler question that has British Gas foxed...trips RCD..
Discussion in 'Plumbers' Talk' started by swags999, Nov 8, 2019.
  1. swags999
    swags999 New Member
    Well BG are out of the picture for a future fix so I need another solution... ! I can call Glow worm who have a fixed price for £249 but I would like to try an understand the issue that might be causing the earth thing first ideally...
  2. terrymac
    terrymac Screwfix Select
    There are quite a few things that can cause an RCD to trip ,moisture or water present on electrics or electronics ( PCB for example), insulation failure ,arcing on a switch , even an accumulation of earth leakage across more than one circuit / appliances ,to name a few. There are many possibilities on your central heating / domestic hot water system alone that can be the root cause ,the boiler ,the programmer ,pump ,motorised valves ,thermostats ,wiring centre etc. Anywhere where current can " escape" from the circuit.
    Its Impossible for anyone on the forum to know where your issue is, that can only be established on site unfortunately.
