Bolts!
Discussion in 'Builders' Talk' started by furious_customer, Apr 12, 2019.
  1. furious_customer
    furious_customer Active Member
    Sigh - for my project I need a few M8 x 90mm bolts. (80mm is too short and 100mm will hit another objkect).
    Why do screwfix, toolstation and B&Q stock M8 bolts in every length except 90mm?
  2. CraigMcK
    CraigMcK Well-Known Member
    M8 threaded bar and nuts?
  3. furious_customer
    Yeah, that might be only option as I need to fit them tonight.
    Then perhaps order the correct size from Amazon and replace them later.
    Can't wait for Amazon to open a trade counter!
  4. DIYDave.
    DIYDave. Well-Known Member
    So you’ve now got a grinder, buy a metal cutting disc, wind nut onto bolt first, clamp into workbench/vice and then cut off what you need
    Norton thin slitting disc, cheap and cuts very well
    furious_customer likes this.
  5. dinkydo
    dinkydo Active Member
    An hacksaw works as well
  6. furious_customer
    That's what I was thinking Dave, but I wonder if after cutting the bolt like this I would still be able to get the nut off or on?
    Not sure if the cut will be clean enought for that?
  7. dinkydo
    The nut will come off easily, an hacksaw cut will leave less rag, put the nut on first then cut, if you want use a metal file to file off any rag and then unscrew the nut it will go back on easily, the link shows two nuts being used but one will do.
    https://www.familyhandyman.com/workshop/cutting-threaded-rod/
  8. DIYDave.
    Read my post again geez ..... :)
    Wind nut on first
    Cut
    Remove nut
    This will straighten the thread at cut point if a little deformed
    Thin metal slitting disc is what you want
    Less than 5 seconds per cut :)
    Of course, as above, could use a hacksaw but you’ve now got a shiny new power tool so why go backwards eh !
    Eg.
    https://www.screwfix.com/p/norton-metal-cutting-disc-4-115mm-x-1-x-22-2mm/8023v
    https://www.toolstation.com/flat-metal-slitting-disc/p35514
    (check disc specs first though for compatibility in instruction manual)
  9. CJASENG
    CJASENG Member
    This is more less what I'd do. Wind Nut on, hacksaw down to size, file the end to a chamfer and unscrew nut.
  10. furious_customer
    Gotcha...this is exactly what I will do - thanks!
  11. furious_customer
    Thanks guys, worked a treat - put a 1mm cutting disc in the grinder and chopped the 110mm bolts down to 90mm.
