here's a nice little problem i've just found. watch out for this one. installing a twin rcd 17th edition cu i put the two lighting circuits on separate rcds (minimising inconvenience). switch everything on and both rcds trip. it was common practice when i was a boy to wire the two gang switch at the bottom of the stairs with a switch wire from the hall light and strappers to the upstairs switch. the switch feed fed both sides of the two gang. this means that the landing light has a live from the downstairs circuit but a neutral from the upstairs circuit. this unbalances both rcds. we're going to find this a lot.
